Washing Machines Logo
Anonymous Posted on Jun 12, 2012
E68 error code
WHAT IS A e68 ERROR CODE?
Kevin Getz
Level 3:
Genius:
  • Master 1,032 Answers
  • Posted on Jun 13, 2012
Kevin Getz
Master
Level 3:
Genius:
Answers
1032
Questions
Helped
331432
Points
3063
If it's a Frigidaire, It's a failure of the touchpad control.
2answers
What is an error code e-68 on a galaxy series dryer mean
E68 error code is a stuck button error code. You can try to wiggle each button on the control panel to make sure they are all functioning freely. If so, then unplug the dryer and leave it unplugged a couple minutes then plug the dryer back in to clear the electronic panel's error code. If the panel still shoes E68, then you'll need to replace the panel. Part#134557201
Hope this helps!!
Jun 13, 2016 • Dryers
2answers
E68 ERROR CODE FRIGIDAIRE DRYER MODEL NO GLEQ2152EE0. CAN YOU DIRECT ME TO A SPECIFIC PART NUMBER?
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
What is Frigidaire gallery dryer code e68
I appreciate your post, friend!
From what you have described your Frigidaire dryer is showing a "E68" error code. "E68" usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! -Matt
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Error code e68
Good Afternoon Friend,
I understand you are receiving an E68 error code on your Frigidaire Affinity washer, model# ATF7000E. The E68 error code states that there is a possibility something is going on with the heating element inside your washer. It could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start your washer on the hottest cycle on a heavy soil level. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Error code 68
Good Morning Mua_m7,
I see that you are having trouble with your Frigidaire washer giving you an E68 error code. The E68 could be one or both of two possibilities.
First, it could be the heating element. If the heating element goes out, this means that you would be unable to get the water temperatures to hotter temperatures.
Second, it could be something going on with the main control board inside your washer.
With you receiving the E68 error code, I suggest that you give your washer a hard reset, by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. When you restore the power, if you are still receiving the E68 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
1helpful
Frigidaire affinity XD71702132 error 68
Please click the link below to see my answer to a similar E68 question on fixya:
https://www.fixya.com/support/t10225683-error_code_e68_frigidaire_affinity
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Do i need a new hard drive if the one i have gives me the e68 error when it it in the xbox when it isn't in it turns on no red light but when i plug it back in i gives me it again. thank you.
Hello! no need to worry! the E68 error code is one of the more simple things to fix. most of the time it's just simply a hardware fluke. Attached you will find detailed instructions on how to successfully restore your hard drive and eliminate the e68 error code. If unfortunately, you must purchase a new hard drive, you can find reasonably priced drives at your local electronics or computer store.
If the steps listed in the link fail, the contact information for Microsoft is included as well. Good Luck!!
How to Fix The E68 Error Code
Top Washing Machines Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
