Freezer works good but the fridge will NOT chill and has error code FF. I unplugged the fridge, the LCD reset but the error code came back. What is the problem? Please help!
This website can help you www.rsgoldfast.com
They serve good high efficiency, safe and convenient transaction, you can go to experience
The price is certainly the cheapest
There is also often very affordable activity
You have a Freezer Fan error. you either have a bad fan motor or you have a bad computer board, you need to call an authorized service tech to determine which.
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
SOURCE: LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
SOURCE: error code Er FF freezer works. fridge does not
The Freezer Fan also provides air for the refrigerator
SOURCE: Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
SOURCE: lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
I had to call a repair man after trying to de-ice the freezer but there was no ice build up. The fan inside the freezer behind the panel failed and will not operate. The repair man said, "I've never seen one fail and don't know when I can get you another one." I will NEVER buy another LG appliance!
