I have a problem with my savin. i have a error code sc396 and i dont know what that means. please help
SOURCE: Hi all, I have a problem with a Ricoh C410dn , the
sc396 is an overload error for the black drum motor. You can try removing and replacing the black drum and making sure nothing is obstructing its movement (like a scrap of paper stuck somewhere or a chipped gear). You might want to have a service technician take a look at it if you can't find anything, to see if the motor needs to be replaced.
SOURCE: Savin 4090 error code
check this link, look under error codes
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
SOURCE: error code
It's fusing web end error code. The fusing assembly needs service work done on it.
SOURCE: Help, SAVIN 3350DNP has a SC05-60 code
SC05-60 is...
Idling HP sensor
remains on. The sensor does not de-activate
after the idling roller motor on
signal is generated.
This sensor is located INSIDE the drum unit. Most likely it is clogged with ink. Possible defective.
