I do not know what the error code f11 means on your appliance but I do know that if you cannot find it in your manual you will obtain the information you require from the manufacturer or a reputable dealer or service engineer. If this error code relates to an open door and you are satisfied the door is properly closed then the switch that closes the circuit that permits your oven to operate is not operating. This may be due to the oven door seal stiffness being just enough to keep the switch contacts apart or it may be due to dirt or grease preventing a clean electrical contact being made.
Hello Nancy Keller - Typically, error code F11 indicates a shorted keypad. Try resetting the wall oven by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
