Apple iPod classic MP3 Player Logo
Anonymous Posted on Dec 13, 2011
My problem is i for got my combination code?
Ipod combination code?..
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
323
Points
8
Forgot my combination code
2helpful
2answers
Can not unlock ipod
How to Unlock an iPod
Your later generation Apple iPod can be locked to protect your personal data from anyone else's eyes. There are a variety of ways to unlock it depending on your access to the combination, the primary computer linked with the iPod, or neither.
Difficulty: Easy
Instructions
Unlock with the Combination
Remember the 4-digit combination you used to set the screen lock.
Enter the exact combination. If the combination is correct, the iPod unlocks and displays the screen you were on before you locked it.
The numbers on the screen flash red if you enter the code incorrectly.
Unlock with the Primary Computer
Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
Open iTunes and sync the iPod as normal.
Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Have a nice day..
I was hearing music and i put the combination and i tryed to un look it and i foregot my combination
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please rate me
2helpful
Unlock screen lock code number
Unlocking iPod You can unlock iPod in one of two ways:
  • Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
  • Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
  1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
1helpful
My iPod is disabled, I don't know the code and I don't have the iTunes account information...I can't prove that I own it.. What do I do?
Ipod Lock
You can unlock iPod in one of two ways: 1...Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen. 2...Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can’t unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize.
Important: Apple representatives cannot unlock an iPod if you forget your combination. If you can’t unlock your iPod and you don’t have access to the primary computer, your only option is to restore the iPod, which will erase all music and data.
Good Luck, I hope this helps
Forgot screen 4 digit pass code
Ipod Lock
Good Luck,
I hope this helps
2helpful
I LOCKED MY IPOD BUT DON'T REMEMBER THE CODE AND WHEN I PLUG IT INTO MY COMPUTER IT'S NOT READING
Ipod Lock
Good Luck,
I hope this helps
I have an apple ipod 30gb and the lock is set and i cannot unlock it.
• Enter the combination code of 4 digit to unlock the iPod. If you enter wrong code combination, the digits onscreen flash red.
• Or Connect iPod to the main computer you use (computer with which iPod synced with), and open iTunes. Now disconnect the iPod from the computer, it will be unlocked.
Locked ipod
You can unlock your iPod nano in two ways:
A Enter the combination on iPod nano by using the Click Wheel to select the numbers
and pressing the Center button to confirm them. If you enter the wrong
combination, it flashes red. Try again.
A Connect iPod nano to the primary computer you use it with, and iPod nano
automatically unlocks.
Note: If you try these solutions and you still can’t unlock iPod nano, you can restore
iPod nano. See “Updating and Restoring iPod Software” on page 50 for more
information.
Ipod security code
â Enter the combination on iPod nano by using the Click Wheel to select the numbers
â Connect iPod nano to the primary computer you use it with, and iPod nano
information.
1helpful
2answers
How do i unlock my ipod with an unknown combination?
heres a link to help http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/ipod-reset-code-to-unlock-scr http://ca.answers.yahoo.com/question/index.php?qid=20070415103140AAM9C03 hope they help
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
woodzowl307
SmartAviator
SmartAviator
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
