Canon PIXMA  iP6700D InkJet Photo Printer Logo
Posted on Aug 27, 2011
WHAT DOES ERROR CODE 6500 ON A CANNON PIXMA IP67000 PRINTER MEAN
5 Related Answers
Mukesh Kumar
  • 3230 Answers
  • Posted on Oct 01, 2009
SOURCE: error code 6500 flashing
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
Mukesh Kumar
  • 3230 Answers
SOURCE: what does the trouble code on a cannon printer
4. Properly seated
Thanks.................
Anonymous
  • 2049 Answers
  • Posted on Nov 16, 2009
SOURCE: cannon pixma mp500 code error 6500
The error code of 6500 is a PCI bus error and this is a Service Error Code. Typically this is an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
Sorry fro the bad news!
Anonymous
  • 74 Answers
  • Posted on May 10, 2010
SOURCE: cannon pixma mp145 printer error code e7 & e2
E2: Reload the paper correctly and press [Black] or [Color].
E7: The cartridges are not installed in place.
These are from the manual.
Anonymous
  • 22 Answers
  • Posted on May 16, 2010
SOURCE: cannon mp150 printer error
sorry, i don`t actually know but i think you should just use genuine catridges
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
