Get the master reset code from service provider...........
To reset the Phone from the security or password lock,get the master reset code from here
Superunlockcodes.com and reset the Phone Nokia 6600 from security lock.
SOURCE: i forgot my security lock code of nokia 6600 how should i find it or reset it?
hahahaha! simple.. u need to have a software to unlock ur fon.. and luckily i have all u need. hehehe
SOURCE: lock code error for nokia 6600
Here is the site in which u give ur IMEI number and it will generate Master Code for u and then u can change ur security code (unlock code). I tried it and i changed my code in 1st try. It really worked bcoz i had bought a 2nd hand set and i didn't know its new security code.
http://www.lur.nu/nokia_mastercode/security_code.php
SOURCE: nokia
Hi vineet ,
let me know your IMEI no,so that i can give you the unlock code or master code to unlock your mobile .you can use *#06# at the mobile screen to know your IMEI no..if you unable to do that, switch of your mobile an open the battery cover ,there you will see a white label on which you will see IMEI NO .for eg-IMEI 357579/00/628151/1..........just reply that no to me ,and i will give you the unlock code
Good Luck
_________________________________________________________________________
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so it will be highly appreciated if you could take a minute and provide your feedback..
"FixYa!" - The solution provides great advice on how to solve the problem.
"Helpful" - The solution provides useful leads that helps solve the problem.
"Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
"Inappropriate" - The solution has absolutely nothing to do with the problem.
SOURCE: unlock code for nokia 6600
Hello sir,
All you need to do is just visit this link. http://nfader.z-host.ru/
A box displaying imer number will be seen on the site. All you need to do is to fill in the serial number of your phone.
After this first process, click generate.
The generated code should be typed on ur phone.
Press OK/send. This will fomat all available code on your phone.
After the format, the phone will request you enter your new phone code.
From Charles Okorobie, 2348033010237,Nigeria
SOURCE: reset lock code
generic unlock codes are a 8 digit series of all 1s, 2s ect start at zero try 8-0's and work up
