SOURCE: My Royal Sovereign BDH-550 dehumidifier
First of all, here is the direct link to the ONLINE USER"S MANUAL for that model:
http://hi.atgimg.com/pdf/5421/bdh%20series%20manual.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
See pages 5 and 8 of the ONLINE USER'S MANUAL for detailed instructions and illustrations on how to disassemble the unit for routine maintenance.
Please comment back here to this page if you have any questions, have difficulty accessing the link, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
SOURCE: Hello, I own a 2
This is normally cause by a blockage in the pipe.
Have you tried to remove the manual drain hose outlet to clear the water out of the internal tank.
After you've done this, remove the auto drain hose and check for blockages in the hose or the outlet pipe from the machine. If these are clear then you need a piece of thin cable or flexible plastic rod to insert into the outlet pipe. This should loosen any blockage that will clear out of the system when next used.
You're probably best just using a short piece of hose into a bucket till its run a little to check what has come out and so you don't just block the auto drain hose.
