20 Most Recent
Python PS5000 SmartStart System Questions & Answers
How to unlock the nokia c3-00
You can get an unlock code for your Nokia C3 mobile phone from
Onlinegsmunlock.com .Here you have to specify your country name,the
current network provider and IMEI number of your mobile phone.Then you
can get an unlock code from them at reasonable cost and unlock it.
8/12/2026 5:35:39 PM •
Cell Phones
Answered
on Aug 12, 2026
Reset my icon screen.
In the event that the touchscreen is inaccessible and a reset is required, please follow the hardware-based reset procedure outlined below:
- Press and hold the power button to turn the device off completely.
- Once the device is off, press and hold the appropriate key combination for your model (commonly Volume Up + Power or Volume Down + Power) until the device vibrates and the recovery mode screen appears.
- In the recovery menu, use the Volume Up and Volume Down buttons to navigate through the options.
- Highlight the option labeled 'wipe data / factory reset' and confirm your selection by pressing the Power button.
- Confirm the action by selecting 'Yes - delete all user data' using the same navigation method.
- Once the reset is complete, select 'reboot system now' to restart the device.
7/30/2026 5:51:27 PM •
Cell Phones
Answered
on Jul 30, 2026
How to get FREE unlock code for ZTE phone
hi,
i just want to share how to get your FREE unlock code in your ZTE phone..some of the askers here are not given the right answer ,they are always giving a link for the network unlocker that costing around 10 to 15 usd dollars..
here is how,
post your phone model and IMEI number at the premium question under the cellular phone category and i will CALCULATE your unlock code for FREE..
EXAMPLE :ZTE sfr 231
IMEI :
356785672134567
after i calculated the Unlocked Code ,here is the procedure to enter it..
- Insert an unacceptable SIM card to locked phone, now phone should ask unlock code (NP code?). Easy just enter code that i was calculated
- Not working?, alright now remove the SIM card and try this code ###825*09# . got the prompt for code? enter the code.
- Failed above, try *983*8284# . It should work.
i hope it will help you ,i am now waiting for your posting of ZTE model and IMEI so that i will calculate your FREE unlock code ..
How to Connect a mobicell to internet
To connect a Mobicell phone to the internet, first check whether you are using Wi-Fi or mobile data.
If you are using Wi-Fi:
- Go to Settings
- Open Wi-Fi
- Turn it ON
- Select your network
- Enter password and connect
If you are using mobile data:
- Go to Settings
- Open SIM or Network settings
- Enable Mobile Data
- Ensure APN settings are correct (usually automatic from your provider)
If you are setting up internet or scanning configuration details, tools like
https://docimgscan.com/ can help you quickly read QR codes and setup information without manual entry.
If it still doesn't work, share your Mobicell model and SIM provider and I'll guide you further.
6/7/2026 11:39:10 AM •
Cell Phones
Answered
on Jun 07, 2026
How to fix a display in the center of a mecer jm777 monitor
If your Mecer JM777 monitor display is not centered, follow these steps to fix it:
1. **Check the Monitor Menu Settings:**
- Press the **Menu** button on your monitor.
- Navigate to **Picture ? Position** (or similar option).
- Adjust **Horizontal** and **Vertical** position until the display is centered.
2. **Adjust Resolution on Your Computer:**
- On Windows: Right-click the desktop ? Display settings ? Advanced display settings ? Ensure the resolution matches the monitor's native resolution (usually 1920x1080 or 1366x768 for JM777).
- On Mac: System Preferences ? Displays ? Set the resolution to **Default for display**.
3. **Update Graphics Driver:**
- Ensure your graphics card drivers are up to date. Old drivers may misalign the screen.
4. **Check Cable Connection:**
- Make sure the VGA/HDMI/DVI cable is securely connected.
- Try a different cable if possible.
5. **Factory Reset Monitor:**
- Access the monitor menu ? **Settings ? Factory Reset**.
- This restores default positioning and often fixes centering issues.
After these steps, your display should be correctly centered on the screen.
4/22/2026 10:13:02 AM •
Cell Phones
Answered
on Apr 22, 2026
Write about Villa Diva Twins.
Villa Diva Twins is a well-known luxury villa Seminyak option, offering a stylish and comfortable stay in the heart of Bali. This modern villa in Seminyak is popular among travelers, including many guests from Australia, thanks to its central location, private pool, and high-quality facilities. When it comes to cell phone use, Villa Diva Twins is well-equipped for modern travelers. Like many premium private villas in Bali, it offers strong Wi-Fi connectivity, making it easy to stay connected, use mobile apps, and manage travel plans. Guests can also use their cell phones for ride-hailing services, restaurant bookings, and communication with villa staff. For international visitors, including Australians, it is recommended to use a local SIM card or an international roaming plan to ensure smooth connectivity during your stay. Overall, Villa Diva Twins provides a comfortable and tech-friendly environment, making it a convenient choice for both relaxation and staying connected while enjoying Bali.Visit_ https://villabugis.com/
4/17/2026 6:00:41 AM •
Cell Phones
Answered
on Apr 17, 2026
I'm locked out of my iphone because I don't know the pass code to get in after an update.
This happens a lot after an update-your iPhone requires the passcode, and there's no way around it. The only reliable fix is to
erase the device and set it up again.
Method 1: Use
iTunes to restore iPhone
Turn off your iPhone
Enter Recovery Mode:
iPhone 8 or later:
Press Volume Up ? Volume Down ? hold Side button
iPhone 7/7 Plus:
Hold Volume Down + Power
iPhone 6s or earlier:
Hold Home + Power
Keep holding until you see the recovery screen
Connect to a computer
Open iTunes
Click Restore
This will remove the passcode erase all data
TunesKit iPhone Unlocker can make the unlock iPhone process more easy. You can try it if possible.
3/18/2026 10:20:31 AM •
Cell Phones
Answered
on Mar 18, 2026
My DZ09 always when I try to install apps it says Time out
So what's the problem
If your DZ09 smartwatch shows "Time Out" when installing apps, it may be due to connection or storage problems. Try the following:
1. **Check Internet Connection**
- Make sure the watch is connected to a stable network or paired properly with your phone via Bluetooth.
2. **Restart the Watch**
- Turn the DZ09 off and then power it back on.
- This can fix temporary system glitches.
3. **Check Storage Space**
- If the internal memory is full, the watch may fail to install apps.
- Delete unused files or apps to free space.
4. **Reset the Watch**
- Go to **Settings ? Restore Settings / Factory Reset**.
- This may fix software issues causing the timeout error.
5. **Check App Compatibility**
- Some apps are not compatible with the DZ09 operating system, so they may fail to install.
After trying these steps, attempt to install the app again.
3/8/2026 8:41:14 PM •
Cell Phones
Answered
on Mar 08, 2026
Restoring deleted emails in May 2019
To restore deleted emails:
1. **Check Trash/Deleted Folder:**
- Open your email app (Gmail, Yahoo, Outlook, etc.).
- Go to **Trash** or **Deleted Items**.
- Emails are usually kept there for 30 days before permanent deletion.
- Select the emails you want and choose **Move ? Inbox**.
2. **Use Web Version:**
- Sometimes the mobile app doesn't show all deleted emails.
- Log in on a web browser to check the Trash folder.
3. **Restore from Backup:**
- If your account is synced with another device or cloud backup, you may recover deleted emails from there.
4. **Contact Email Provider:**
- For Gmail: https://support.google.com/mail/answer/78353
- For Outlook: https://support.microsoft.com/outlook
- They can sometimes recover permanently deleted emails if requested quickly.
**Tip:** Act fast! Once emails are permanently deleted (over 30 days in most cases), recovery may not be possible.
3/8/2026 8:34:45 PM •
Cell Phones
Answered
on Mar 08, 2026
I have a 33102017new version and whenever I send a msg to a specific person it says not sent to that person
If your messages fail to send to a specific person while others work fine:
1. **Check Recipient Number:**
- Make sure the number is correct and not blocked on your phone.
2. **Check Message App Settings:**
- Open your messaging app ? Settings ? Ensure the SMS service center number is correct (this is often pre-configured by your carrier).
3. **Try Another Messaging App:**
- Use apps like WhatsApp, Signal, or Telegram to see if messages go through. This helps check if it's the carrier or the phone.
4. **Clear App Cache:**
- Go to Settings ? Apps ? Messaging App ? Storage ? Clear Cache. Don't clear data unless necessary.
5. **Restart Phone & SIM:**
- Switch your phone off, remove the SIM, wait a minute, and reinsert it.
6. **Contact Carrier:**
- If the problem persists, your carrier may have restrictions on sending messages to that number.
Following these steps usually resolves issues sending SMS to a single contact.
3/8/2026 8:31:44 PM •
Cell Phones
Answered
on Mar 08, 2026
Is there a user guide / manual to suit RMC2065 Regards
To get a user guide for the RMC2065:
1. **Check Manufacturer Website:**
- Visit the official website of the RMC2065 manufacturer (look on the device or box for brand info). Most manufacturers offer downloadable PDFs.
2. **Search Online:**
- Use Google with keywords: `"RMC2065 user manual PDF"` or `"RMC2065 instruction manual"`.
3. **Third-Party Manual Sites:**
- Websites like **ManualsLib**, **Scribd**, or **SafeManuals** often have scanned manuals available for download.
4. **Contact Support:**
- If you can't find the manual online, contact the manufacturer's customer support. Provide your model number, and they can email or direct you to a PDF.
Following these steps should get you the official manual or instructions for your RMC2065 device.
3/8/2026 8:30:49 PM •
Cell Phones
Answered
on Mar 08, 2026
How do I change the font size for incoming messages on an Oppo AX5 please? It does not respond to the font bar in the settings.
To change the font size for incoming messages on your Oppo AX5:
1. **Use System Font Settings:**
- Go to **Settings ? Display & Brightness ? Font Size**.
- Adjust the slider to increase or decrease font size. This affects system-wide text, including messages.
2. **Check Messaging App Settings:**
- Open the **Messages** app.
- Tap the **three-dot menu ? Settings ? Text Size** (if available) and adjust.
3. **If changes don't apply:**
- Restart your phone after changing font size.
- Make sure your **Messages app is updated** via Google Play Store.
4. **Alternative:**
- Install a third-party messaging app like **Textra** or **Signal**, which lets you set font size independently of system settings.
These steps should let you control the font size for your messages.
3/8/2026 8:29:57 PM •
Cell Phones
Answered
on Mar 08, 2026
Activate my phone
To activate your phone, follow these general steps:
1. **Insert SIM card:**
- Make sure your SIM card is properly inserted.
2. **Charge your phone:**
- Fully charge the phone before activation.
3. **Turn on the phone:**
- Press and hold the power button until the device boots.
4. **Follow on-screen setup:**
- Choose language, connect to Wi-Fi (if required), and log in to your Google/Apple account.
5. **Carrier activation (if needed):**
- Some phones require activation with your mobile carrier. Contact your carrier if activation doesn't complete automatically.
6. **Restart your phone:**
- If it still isn't activated, restart the phone and try again.
After these steps, your phone should be activated and ready to use.
3/8/2026 8:28:58 PM •
Cell Phones
Answered
on Mar 08, 2026
How come my songs keep pausing and I have to un pause them to play again on my audiomack app just start happening all of a sudden.
If your songs keep pausing in the Audiomack app, it may be caused by app glitches, internet issues, or phone settings. Try these steps:
1. Restart your phone to refresh the system and apps.
2. Check your internet connection.
- Audiomack needs a stable Wi?Fi or mobile data connection for streaming.
3. Clear the Audiomack app cache.
- Go to Settings ? Apps ? Audiomack ? Storage ? Clear Cache.
4. Update the Audiomack app from the Google Play Store or App Store.
- An outdated version may cause playback problems.
5. Disable battery optimization for the app.
- Go to Settings ? Battery ? App management and allow Audiomack to run in the background.
After trying these steps, open Audiomack again and check if the music plays without pausing.
3/8/2026 8:26:18 PM •
Cell Phones
Answered
on Mar 08, 2026
How change I fix "INACTIVE ERR"
If you are seeing "INACTIVE ERR" on your device, it usually indicates that the service, SIM, or account is inactive. Here's how to fix it:
1. **Check SIM/Service Status:**
- Make sure your SIM card is active and inserted correctly.
- If it's a prepaid SIM, ensure it has enough balance or is not expired.
- Contact your mobile carrier to confirm that your line is active.
2. **Restart Your Device:**
- Turn off your phone.
- Remove and reinsert the SIM card.
- Turn the device back on.
3. **Network Settings Reset:**
- Go to **Settings ? System ? Reset ? Reset Network Settings** (Android) or **Settings ? General ? Reset ? Reset Network Settings** (iPhone).
- This clears any network conflicts that might cause the "INACTIVE ERR".
4. **Update Device Software:**
- Go to **Settings ? System ? Software Update**.
- Install any available updates. Some "INACTIVE ERR" issues can be fixed by software patches.
5. **Test with Another SIM (Optional):**
- Insert a different active SIM into the device. If it works, your original SIM may be faulty.
If none of these steps work, contact your carrier for further assistance-they can reactivate your line or provide a replacement SIM.
3/8/2026 8:24:47 PM •
Cell Phones
Answered
on Mar 08, 2026
Comment connecter mon iPhone?
To connect your iPhone to another device (like Wi-Fi, Bluetooth, or computer), follow these steps:
1. **Connect to Wi-Fi:**
- Go to **Settings ? Wi-Fi**.
- Turn Wi-Fi on and select the network you want to join.
- Enter the password if required.
2. **Pair with Bluetooth Devices:**
- Go to **Settings ? Bluetooth**.
- Turn Bluetooth on.
- Put your other device in pairing mode and select it from the list on your iPhone.
3. **Connect to Computer (for syncing or charging):**
- Use a **Lightning cable** to connect your iPhone to your computer.
- Open **iTunes** (Windows) or **Finder** (Mac) to sync or backup your iPhone.
4. **Connect to Car or Audio System:**
- Use Bluetooth or USB depending on your car's system.
- Refer to the car/audio system manual for iPhone pairing instructions.
After following these steps, your iPhone should be successfully connected to the desired device.
3/8/2026 8:23:07 PM •
Cell Phones
Answered
on Mar 08, 2026
