20 Most Recent Google Wallet for Android Questions & Answers
tip
How To boost Battery Power In Android
Are you suffering from the rapid battery drainage on your Android? If so, try the Greenify app in the Google Play store. It hibernates the app that are running in the background and saves more battery power than before. I hope my tip will be useful Android users . It can hibernate the app that
on Sep 17, 2020 • Android Apps
tip
How to Play Music and Record Video on an Android Phone
As an Android user myself, I know how irritating it is when you are recording a video and try to play a song, but it stops recording. Thankfully, I found an app that works in the background: Background Video Recorder Apps on Google Play . However, you have to follow the following steps to play a song at the same time as recording: Step One: Install Background Video Recorder Step Two: Open your music app (Google Play Music, Youtube Red, Spotify, etc.) Step Three: Start playing the song Step Four: WITHOUT pausing the music, open Background Video Recorder app and begin recording. When you are done recording, hit STOP in the Background Video Recorder app and enjoy your video [DISCLAIMER] This tip is not an advertisement. I make no money from Background Video Recorder app for posting this and I endorse the product purely for the betterment of other Fixya users.
on Nov 02, 2018 • Android Apps
tip
How to Fix “Unfortunately, Android Keyboard Has Stopped”
Clear cache of the keyboard app you are using, and if that does not fix the problem clear the app's data. Clear the cache and data of the Dictionary app. Reset the keyboard settings. Go to Settings > Language and Input > Samsung Keyboard > Reset Settings. How to Fix Unfortunately Android Keyboard Has Stopped Technobezz How to clear an app's cache and fix app crashes in Android
  1. Open the Settings menu and choose Application Manager. ...
  2. Tap the All tab, then look for and tap on the troublesome application - in this case 'Samsung Galaxy'.
  3. In this order select Force Stop, Clear Cache, Clear Data.
  4. Restart the phone and all should be well
How to fix app crashes and clear an app cache in Android How do I get my keyboard back to normal on Samsung?
Swype keyboard
  1. From the Home screen, tap the Apps icon.
  2. Tap Settings. If necessary, tap General management.
  3. Tap Language and input.
  4. Tap Default keyboard.
  5. Tap ADD KEYBOARDS.
  6. On Google voice typing, move the switch to ON.
Keyboard Samsung Galaxy S7 Samsung keyboard keeps on stopping Google Search
on Dec 17, 2017 • Android Apps
tip
How to Fix The Dead Android and Red Triangle
I think it,s time for a factory reset , you will lost all you data !!!!! 1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly. 2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears) 3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up). 4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons. 5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections. 6. Use the volume buttons to move up and down through selection in this menu. 7. Using the volume down button, scroll down to "Wipe data/factory reset" 8. Tap Power hard key to select option. 9. Scroll down to select "Yes, delete all user data". 10. Tap the power button to select. Wiping and formatting data will take a few minutes. 11. You will return back to the Android recovery screen menu. 12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet. android man on his back with red triangle on his chest Google Search
on Dec 15, 2017 • Android Apps
tip
How To Skip Android Google Play Signup When Playing Games
Hi, friends how are you... in this tip, you going learn about that how to skip google play games signup when playing android games. did you feel that when you open android games there you can see a pop-up window saying that signup for the google play game to play this app looks irritating right? don't worry dude there is the very simple solution for this problem. If you see that window in future just touches somewhere on the screen tada.... the signup window will be gone....
on May 01, 2017 • Android Apps
My htc one x is very slow
Hi,(H) means HSDPA, which means faster internet connection.It is also called as 3G.If you turn off your internet connection, you can't see (H).Cheers...!!!
11/29/2012 11:34:05 AM • Google Android... • Answered on Nov 29, 2012
How to connect my cricket lg android to my tv
is your mobile have hdmi or tv out like option if yen then you try
5/20/2012 3:38:26 AM • Google Android... • Answered on May 20, 2012
5801 camera not working it show camera faild
it is application problem uninstal and reinstal it again and try
5/18/2012 2:25:48 PM • Google Android... • Answered on May 18, 2012
My phone samsung galaxy fit GTS 5670 it is a high
The phone has an ARMV6 CPU (Qualcomm MSM7227) so you should download and install Flash player for that CPU version.Best check the link on XDA:http://forum.xda-developers.com/showthread.php?t=1306487
5/18/2012 6:19:47 AM • Google Android... • Answered on May 18, 2012
I made a new google account and i want it to go
If referring to 2 way verifications, login to google account and account settings, deactivate verification.
5/17/2012 7:56:10 AM • Google Android... • Answered on May 17, 2012
Will not play videos on my phone
Depends on the phone specifications, CPU generaterion (6,7, neon,...) and of course application.Try using Rockplayer, Moboplayer or MX player which feature software video decoding and should play without any problems.
5/17/2012 7:53:50 AM • Google Android... • Answered on May 17, 2012
How to i add a google to my pandigital? It keeps
You are trying to add new account?Try using full address with gmail.com, if still unsuccesful, try using googlemail.com.If still doesn't work try to login from PC (or phone browser to check if the account can be accessed- maybe 2 step google verification active?)
5/17/2012 7:50:29 AM • Google Android... • Answered on May 17, 2012
Retriave. Old messages form phone. # 765-571-2163
Push the number 1 to dial voice mail. Input the personal identification number.
5/6/2012 1:19:52 AM • Google Android... • Answered on May 06, 2012
How can you download pictures on a Pandigtal 7
you should *** more
12/28/2011 12:19:00 AM • Google Android... • Answered on Dec 28, 2011
LG AXIS CAMERA APP NOT RESPONDING..WHAT COULD BE
Hello Woody,
Try using app after each step.
First thing to try is somewhat obvious but restart your phone, will solve a majority of the little issues that pop up.
Go into settings/applications/manage applications, then click the all tab. If the camera app you are having issues came with the phone it will be named "camera", click clear data
Navigate to the same screen in settings and uninstall the application(Cannot uninstall the app that was preinstalled)
Use google market to install any high rated camera application.
Factory reset, this will wipe all of the information off of the phone, and return the software to the condition it was in the day you purchased it. Settings/SD card & phone storage/Factory data reset/Reset phone.
If none of these steps have fixed your issue contact your service provider, and they will be able to help you get a replacement. With any luck free of charge.
Good luck, hope this was helpful
12/20/2011 9:47:30 AM • Google Android... • Answered on Dec 20, 2011
My Google account has been
Best practice would be to contact google support, they will respond in 48 hours and will be able to give you information why was it disabled.
9/21/2011 11:48:23 AM • Google Android... • Answered on Sep 21, 2011
5answers
I need help finding a desk for my kid under 100 dollers
Sorry we don't do that here.
7/24/2026 4:18:24 AM • Android Apps • Answered on Jul 24, 2026
3answers
Bypass my Android (Go Edition).
Question edited for clarity. Question moved from Misc to Android.
How to ANDROID GO EDITION Bypass FRP Lock All
GSM-ONE.INFO https://www.gsm-one.info > how-to-android-go-edition-... Oct 29, 2018 - Hard Reset/Factory Reset Coolpad N3 /N3 mini ' How To Bypass FRP Lock Google Account Android 9 ( Android P)
How to Bypass FRP on Android without OTG or Computer
iMobie https://www.imobie.com > Android Unlock Aug 14, 2024 - First, download FRP Bypass APK 2023 on your phone. · Copy and paste the APK file to the USB flash drive. · You need an OTG cable to connect the ...
How to Bypass FRP (Google Lock) with/without PC
iToolab https://itoolab.com > unlock-android > how-to-bypass-go... May 27, 2024 - How to Bypass FRP Lock on Samsung/Motorola/Huawei without PC · 1. Tap the email box on the verify your account screen. · 2. Click on the gear icon ... ..
7/24/2026 4:15:01 AM • Android Apps • Answered on Jul 24, 2026
Google Wallet for Android Logo
2 questions posted
Popular Products
Google Translate
Google Translate
0 Questions
Google Voice
Google Voice
5 Questions
Google Finance
Google Finance
0 Questions
Google Search
Google Search
0 Questions
Top Google Apps Experts
Narseman
Anonymous
Are you a Google App Expert? Answer questions, earn points and help others
View Most Popular
Google Android Apps
  • Google Android Apps
Most Popular Question
5801 camera not working show camera
  • Android Apps
